I just wanted to say Thanks I hope this helps I know my husband worked on a valve cover gasket because it smoked when we first got it, but it hasn't since he worked on it . Thanks again !
[quote:2c7dafb8a6="nunen"]I recently had the same issue. with a Check Engine light on... they told me that #2 & #8 were mis-firing... The problem was coming from the boot on the coil pak. The boot was swelled with oil due to a valve cover gasket leak that I had, valve cover gaskets were replaced and the check engine light came on within a week with the misfiring problem...
The garage said that the boot could not be purchased separately and the coil paks would be $114 each, while a local parts store had them for $55 each.
Not sure if that helps, but that was my experience.
~Nunen[/quote:2c7dafb8a6]
Aug 23, 2007 at 6:44 AM
