2005 Lincoln LS Missfire / Backfire
2005 LINCOLN LS
70,125 MILES • 6 CYL • 2WD • AUTOMATIC
57CHEVY123
Replaced coil on #1 & #4 plugs two months ago. Now, I have a backfire/ sometimes from take-off and a missfire sometimes at speeds of 50 to 60 AGAIN? Scanner at parts store is showing missfire/catalic converter problem. Dealer ship wants to replace four coils and Catalic converter. Service manager says the catalic converter is going out but also wants to do a tune-upand replace 4 coils? They will not replace the converter that is under warranty only? They want to do all kinds of replacements? Once i'm past 60 the car runs great?
Dec 15, 2008 at 2:10 PM
JAMES W.
  • 2,394 POSTS
What ECM codes did they pull?
This sounds like a situation that requires a little "creative maneuvering". It sounds like the dealer believes the convertor is bad and under warranty, hence they have to replace it for free. To help offset the "freebee" they can sell you 4 coils and whatever else they can squeeze in. You may want to get a 2nd opinion. If one or two of the coils test bad, have them changed, by whomever you choose, and have them explain to you whatever else you may need. Take the reciepts back to the dealer and ask about the convertor. You can go from there. The one thing we try to impress upon people is, you are in charge, not the dealer. It's your money. Hope this helps.
Dec 15, 2008 at 2:57 PM
57CHEVY123
I spoke with the service manager and he did not have the ECM codes? He said that the #1 & 6 coil needed replacing. I replaced the #1 coil 5 months ago? He told me that the top manifold had to be removed in order to replace the #1 coil. I told him that I did not have to remove anything when I replaced it 5 months ago. I am going for my car, I will replace thos two coils, then, I will go back and tell them to please replace my converter.
Dec 15, 2008 at 4:04 PM
JAMES W.
  • 2,394 POSTS
Sounds like a plan to me. Let me know how it comes out. Not that I'm against dealerships by any means. They're so used to people giving them a painful look and then writing the check, they're not used to being questioned. You get 2 "ataboys" for that one.
Dec 15, 2008 at 5:20 PM
57CHEVY123
The only ECM code pulled was P302? The service manager mentioned an inbalance between the #1 & #6 cylinders? What could they of done to my car, it runs better...I don't notice the misfire anymore? Should I go ahead and replace the two coils and then take it back for the converter?
Dec 16, 2008 at 7:25 AM
JAMES W.
  • 2,394 POSTS
You could go ahead and change the coils, if you want to. It surely can't hurt anything. Your saving yourself $85+ an hour for labor charges. Also, I can hear the dealer saying, "We can't change the convertor under warranty 'cause the bad coils will ruin it".
Dec 16, 2008 at 1:12 PM
