2005 Lincoln LS car problems
2005 LINCOLN LS
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDDEN3
i have a 2005 lincoln ls i wanted to know why when i turn the a/c on the car starts to stall and feel like it wants to shut off. also when i turn the a/c on the car feels like it doesnt have much power it hesitates upon acelleration. i have had the fuel filter changed. when the a/c is not on the car drives just fine
Aug 30, 2010 at 5:09 PM
ERNEST CLARK
  • 1,730 POSTS
When you turn on the a/c, the pump creates an extra load on your engine it has to deal with.
Usually it's no problem. But if your ignition system/fuel system isn't in proper tune, it won't be able to handle the extra load.
First do a tune up if you haven't already done so. Also, check the fuel pump. (pressure test)
Sep 20, 2010 at 5:53 AM
