2005 Lincoln LS
2005 LINCOLN LS
WOITEK
Electrical problem
2005 Lincoln LS V8 Two Wheel Drive Automatic
Hi ,I have Lincoln ls 2005 ,I just replaced air bag module , becouse the air bag lhite was on ,the car was flooded so has water damage,after that the abs light came on .I check with my abs scanner and showing that the air bag vin dosnt mach,i notice that the number on the old air bag module and abs match but that new air bag module has different number but the air bag light is gone .Do the numbers on air bag module and abs has to match?
Oct 11, 2010 at 10:17 PM
BMRFIXIT
  • 19,053 POSTS
Use the scanner and select PCM data (generic scanner function test )
read VIN # stored in the PCM it should match with the vehicle VIN if not
PCM need to be flashed and programmed with the correct vehicle VIN
Oct 12, 2010 at 6:08 AM
