Failure to rev in park
2003 LINCOLN LS
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELADSILLE
The car was taken in for a smog check (CA). The test could not be performed because the engine would not rev to and hold 2,500 rpm's. When driving, rpm's are not an issue. appropriate rpm at speeds and shifts (both automatic and manual shifting). Will rev some in park when cold but not at all when warm. Idle is fine.
May 9, 2009 at 1:58 PM
MERLIN2021
  • 17,250 POSTS
Any warning lights on on the dash? Wrench light?
May 10, 2009 at 8:42 AM
ELADSILLE
No. The engine line was on but sensor reset. No lights now.
May 10, 2009 at 12:06 PM
MERLIN2021
  • 17,250 POSTS
Please explain, was it reset by a scantool? Or did the car's own computer turn it off? Did you get the code when it was lit? Try going to AutoZone they will read the codes for free, ask them to read the "freeze frame data" and post that if you can.
May 11, 2009 at 4:00 PM
I to have a 2003 Lincoln V6 not revving in park. I recently replaced an EGR valve and cleared code P0401. Car has been driven one hundred and fifty miles. What can I do to get it to rev?
Jul 19, 2018 at 7:43 AM
On newer cars the computer will not allow the engine to rev in neutral or park. Can you take a video of what the engine is doing and upload it here to the site so I can be sure?
Jul 19, 2018 at 11:11 AM
I recently replaced the EGR valve and cleared code P0401. Car has been driven one hundred and fifty miles. What can I do to get it to rev in park?
Jul 20, 2018 at 11:18 AM (Merged)
The engine will not rev in park or neutral. Can you upload a video so I can see what it is going? You can upload it from your phone to the site in your response.
Jul 20, 2018 at 11:20 AM
