My power window fuse keeps blowing whenever my window either gets all the way to the top or all the way to the bottom. My window regulator broke, so I bought and replaced the entire unit (with motor) from Autozone. After installing the new unit, I find this fuse blowing problem. The original window problem was a broken nylon pulley that the cable passed through. I had to replace the entire regulator (which included a motor). The original Lincoln motor will not fit the Autozone regulator. I'm not sure if the problem is with a bad Autozone motor (that's part of the new regulator assembly) or did I pinch a wire causing a short? I'm not sure how to search for a short. I visually double checked all my harnesses inside the door and could not locate anything that might look like a pinched wire that's grounding out.
Sep 5, 2010 at 7:44 PM
