2002 Lincoln LS missing
2002 LINCOLN LS
89,000 MILES • V8 • 2WD • AUTOMATIC
TWOWIN
at speeds of40 t0 50 mph she misses and cuts out alredy replaced 3 coils and sparks plugs.
Aug 1, 2010 at 5:14 PM
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 1, 2010 at 5:32 PM
