2002 Lincoln LS High RPM
2002 LINCOLN LS
169,000 MILES • 6 CYL • 2WD • AUTOMATIC
ERIC2
Replaced spark plugs, pcv, all intake gaskets car will start but will not idle will stay around 1500 rpm have a code p1120 replaced the tps but still have the same problem. Still have high RPM.
Oct 28, 2008 at 1:14 PM
Hi eric2 and welcome to 2carpros
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
Oct 28, 2008 at 2:07 PM
