2000 lincoln ls v-6
2000 LINCOLN LS
MACHADO
my car dies out only in the idle position i put my code reader on it and it read po171,system to lean bank 1.i have no clue what to look for.need help thanks.
Feb 7, 2007 at 10:42 PM
TECH1JONES
  • 10 POSTS
You need to check fuel Presure... the port is on the drivers side of the motor under the plastic cover. if the pressures low it may need a fuel filter.... if there is none it may be a bad fuse/relay/pump.
Nov 20, 2009 at 11:38 AM
