2000 Lincoln LS radiator fan
2000 LINCOLN LS
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
LSRIDANGA
I recently replaced my radiator and ac compressor and now my fan will not come on and the coolant is shooting out of the reservoir due to over heating i already replaced the power steering pump and am just curios as to which and where is the fuse and relay bc im sure it has to be one of those things if not both.
Jul 14, 2010 at 11:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse 105 (20 AMP) in the underhood junction box, right front of engine compartment. there is no relay on the cooling fan circuit. if fuse is good then test to make sure fan is getting power. if no power then could be bad cylinder head temperature sensor, hydraulic fan solenoid, a/c cycle switch or the PCM. if it has power but doesn't come on then fan motor is bad.
Jul 14, 2010 at 1:05 PM
