2000 Lincoln LS blown fuse
2000 LINCOLN LS
107,000 MILES • V8 • 2WD • AUTOMATIC
SHOCKER1
what would cause 10 amp fuse on clutch to blow ,thanks,update put 15 amp fuse in . now clutch fuse holds engages compressor but no cold air comes out ! does it need charge of freon ?
Aug 30, 2010 at 4:34 AM
ERNEST CLARK
  • 1,730 POSTS
putting a higher amp fuse in place of the factory fuse is dangerous. You could set your car on fire.
If a fuse blows, it means there's a problem in the circuit that needs to be found and fixed.
Also, is the blower motor coming on??? If the compressor is engaging and the blower motor is on but still no cold air, you'll need to check the charge in the system and check for a possible blockage.
Sep 20, 2010 at 5:57 AM
