Turned car off in driveway, will not start. No DTC code present. No fuel pressure to rail. Changed the fuel pump and Crankshaft pos sensor. Still no pump action.
Power to pins 9 and 7 on fuel pump module. No pwr to pin 1.
Fuel injectors do not pulse. Manually applied power to pump and got gas and pressure to fuel rail. No pulse found at injectors with test light. No clicking sounds at any injector.
The ignition is working - had fire at two separate plugs.
Is there a common link between the activation of the fuel pump and triggering of the injectors. My next tests will be of these items. Any advice in the right direction will be appreciated.
MAF sensor
Camshaft Sensor
PATS system
Lighting Control Module ( This may be bad. The chimes, turn signals, etc do not work. My son's car so I don't know how long they have been out)
MAF sensor
Camshaft Sensor
PATS system
Jul 6, 2010 at 8:46 AM
