1998 Lincoln Continental Electronic Control Unit
1998 LINCOLN CONTINENTAL
PUBTECH
Computer problem
1998 Lincoln Continental V8 Two Wheel Drive Automatic
In the trunk area of a 1998 lincoln continental an electronic control unit is mounted in the front of the truck up above just behind the seat and next to the amplifier.
What ECU is it (ignition, sound, etc.)?
Panasonic made???
Jul 17, 2009 at 7:15 PM
Hello, what are you asking, were the ecm is or?
Jul 20, 2009 at 12:46 PM
PUBTECH
I traced a battery draining short to an ECM connector. The ECM is located in the front of the trunk up above. I normally do not work on automobiles (I work on very heavy equipment and aviation) and am not familar with these type PLC's (ECM). When I disconnect the ECM connector I lose the draw.
I tired locating the ECM using the ford number on the internet with no luck.
I just want to know what ECM is this? Is it the igniton ECM or engine ECM of what? It was manufactured by Sylvania for Ford.
I am trying to determine if I should replace the ECM of get a schematic and trace the ECM inputs and outputs for a short.
Thanks,
Keith Barnett
Jul 20, 2009 at 7:52 PM
2CARPRO JACK
  • 11,533 POSTS
My locator shows a couple of controllers in the trunk
Isolator/radio antennae module
Phone support electronics module (PSE)
Remote Emergency Satellite Cellular Unit (Rescu)
Vehicle Dynamic Modle (VDM)
Jul 21, 2009 at 12:41 PM
PUBTECH
I talked to Ford earlier today and it turns out the ECM is the adjustable suspension ECU.
Thanks for the help,
Keith Barnett
[email protected]
Jul 21, 2009 at 4:57 PM
