drivers door open light and beeper?
1995 LINCOLN CONTINENTAL
120,623 MILES • V8 • 2WD • AUTOMATIC
VOPAMELA
  • 18 POSTS
light wont go out and beeper stayson
Oct 6, 2010 at 11:43 AM
KHLOW2008
  • 41,814 POSTS
Hi vopamela,
Check the door switch. It is either not closing correctly or is shorted to body. Manually push the door switch and check if the light goes off.
Oct 6, 2010 at 3:41 PM
VOPAMELA
  • 18 POSTS
i disconnected swittch and light still on
Oct 6, 2010 at 4:08 PM
KHLOW2008
  • 41,814 POSTS
That eliminates the switch as the cause.
Is the door courtesy light staying on as well?
The circuit is being grounded somewhere or the Lighting Control Module (LCM) could be faulty.
LCM is located at left side of instrument panel.
Would you be able to perform diagnostics and do you have a test lamp?
Oct 6, 2010 at 4:23 PM
VOPAMELA
  • 18 POSTS
all the passenger doors are okay.the drivers door is the problem.do i have to change the switch?can i bypass the switch to check if it is no good?how can i bypass the switch?
Oct 6, 2010 at 5:19 PM
VOPAMELA
  • 18 POSTS
sorry i left this out.yes the dome lights are on.i just bought vehicle and had no horn.fuses were good i found plug disconnected on steering colomn that is when buzzer wont shut off.fuses also removed for dome light.i guess he had a problem.
Oct 6, 2010 at 5:27 PM
KHLOW2008
  • 41,814 POSTS
You mentioned unplugging the door switch did not result in the dome light and beeper going off so it is not the cause.
Get a DVOM and unplug the Left Front Door Module, (power window switch assembly of driver door panel).
Unplug the door switch.
Look for a Dark Blue wire and test it for continuity with body. If continuity is present, the wire is shorted between the door switch and the control unit. Usually such shorting would occur around the door pillar where the wireharness comes out of the body and goes into the door panel. Du to constant opening and closing of the door, the wires can be exposed resulting in shorting.
Oct 7, 2010 at 7:27 AM
VOPAMELA
  • 18 POSTS
There are two door switches i disconnected both same problem.Should i run wire to LCM from door switch the blue wire that is?I have LCM out what do you want me to check?
Oct 7, 2010 at 10:27 AM
KHLOW2008
  • 41,814 POSTS
Not the LCM. You need to check the Left Front Door Module which is incorporated into the master control switches.
Oct 7, 2010 at 10:47 AM
VOPAMELA
  • 18 POSTS
What do you want me to do?I checked blue rom switch to plug on master control it is good.
Oct 7, 2010 at 10:58 AM
VOPAMELA
  • 18 POSTS
D/door light is going off and on.
Oct 7, 2010 at 11:00 AM
VOPAMELA
  • 18 POSTS
I did play with harness and put back together and found that lower door switch is no good.When i disconnect beeper stops but dome light still on.Help Please.
Oct 7, 2010 at 12:09 PM
KHLOW2008
  • 41,814 POSTS
Unplug the door switch and master control connector and test if the Blue wire has continuity to body.
Oct 8, 2010 at 7:50 AM
VOPAMELA
  • 18 POSTS
door switch is no good.I disconnected and beeper stopped.Lights are okay but i guess from starting for just a few minutes at a time service engine light came on .Any suggestions.
Oct 8, 2010 at 8:09 AM
KHLOW2008
  • 41,814 POSTS
Get a free scan done at Autozone and let me know the EXACT trouble codes retrieved.
Oct 8, 2010 at 8:27 AM
VOPAMELA
  • 18 POSTS
The trouble code is P0133
Oct 10, 2010 at 12:55 PM
KHLOW2008
  • 41,814 POSTS
P0133 = Upstream Heated Oxygen Sensor ( H2OS 1 ) circuit slow response ( Bank # 1)
I will send the diagnostic files to you as it is too large to be posted here.
Oct 11, 2010 at 8:56 AM
VOPAMELA
  • 18 POSTS
is anyone gonna try to help me?
Oct 11, 2010 at 5:06 PM
VOPAMELA
  • 18 POSTS
Sorry about the question i just sent.Thanks in advance!
Oct 11, 2010 at 5:30 PM
KHLOW2008
  • 41,814 POSTS
Have you received the files I sent you?
Oct 12, 2010 at 10:28 AM
VOPAMELA
  • 18 POSTS
No. How did you send it to me? Was it by the USPS?
Oct 12, 2010 at 9:28 PM
KHLOW2008
  • 41,814 POSTS
Check your email.
Oct 13, 2010 at 9:23 AM
VOPAMELA
  • 18 POSTS
Very helpful.Thank you very much.You are a lifesaver.
Oct 14, 2010 at 7:36 AM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Keep me updated of the outcome.
Oct 14, 2010 at 7:59 AM
VOPAMELA
  • 18 POSTS
It was oxygen sensor on right bank.Sorry i took so long to reply but i had to go out of town on very important business.Your notes did the trick very easily.Thank you very much.
Nov 2, 2010 at 5:58 PM
KHLOW2008
  • 41,814 POSTS
Glad to know you have fixed the problem.
Thank you for using 2carpros and have a great day.
Nov 2, 2010 at 6:51 PM
VOPAMELA
  • 18 POSTS
my service light came back on and the code is p1518.Autozone said it is the intake manifold runner control stuck open.What is that?
Nov 4, 2010 at 5:49 PM
KHLOW2008
  • 41,814 POSTS
It is trouble code for the IMRC stuck open.
Possible causes are :
Cables improperly routed, binding or seizing.
Damaged or disconnected IMRC housing return spring.
Lever stop obstructed or bent.
Lever wide open stop obstructed or bent.
IMRC actuator cable or gears seized.
The diagnostic file have been sent to you. Check your mail.
Nov 4, 2010 at 10:20 PM
