1994 Lincoln Continental ENGINE OIL PRESURE
1994 LINCOLN CONTINENTAL
197,000 MILES • 6 CYL • FWD • AUTOMATIC
THALL10
OIL PRESSURE INDICATOR SHOWS INTERMITANT DROP IN PRESSURE WHILE DRIVING. TAKES SEVERAL MINUTES TO RETURN TO NORMAL OPERATING RANGE.
DO i NEED A NEW OIL PUMP? iF SO, iS THIS SOMETHING i CAN INSTALL IN MY GARAGE?
Jan 1, 2009 at 11:49 AM
BUDDYCRAIGG
  • 2,262 POSTS
you need to put a mechanical gauge on it to see if it's really a oil pressure problem.
or if the electrical sending unit is flaking out.
Jan 1, 2009 at 8:32 PM
ALLBROWN
  • 27 POSTS
Hey !! Check the cheaper job 1st ... above your exhaust right b4 thee cadillac converter sits an oil pressure sensor . It gets old & leaks on to the exhaust , resulting in a burnt oil smell . Good luck fellow wrencher .
Jan 31, 2009 at 6:29 PM
