1994 Lincoln Continental dcl check light comes on
1994 LINCOLN CONTINENTAL
15,500 MILES • 6 CYL • FWD • AUTOMATIC
TONEY A GARRETT
how do i check for a dcl check on a 1994 lincoln where do i lok to fix it
Oct 24, 2008 at 3:41 PM
JOEPETERSON56
  • 5 POSTS
DCL or Diagnostic Connector Link is located in the trunk on the left side, behind the carpeting right where the rear left tire wheel well starts up from the trunk floor. There should be an opening in the carpet and the wire is pined to the metal support plate there. Als mounted just below that is a switch for the air ride suspension, as well as the fuel cut off switch.
Jan 9, 2010 at 5:55 PM
