1994 Lincoln Continental car shakes when accelerating
1994 LINCOLN CONTINENTAL
105,000 MILES • 6 CYL • FWD • AUTOMATIC
JFANTAUZZI
Couple of things. for awhile when driving if accerate wouldn't shift past second gear and would have to shut off and restart. for example if taking a turn you slow down to about 20 mpg and if you don't let it shift down before you accelerate then it woouldn't shift past 3rd. now when you accelerating between 20-30MPH if you have the gas down to far the car shakes. once past 30 stops. You can' floor the car at all or take off fast if you need to get moving. Any thoughts?
Was thinking of replacing fuel filter because it probaby hasn't been done. Also was going to have the transmission look at.
Dec 19, 2007 at 10:15 AM
Sounds more like its coming from the transmission
Dec 19, 2007 at 1:24 PM
JFANTAUZZI
[quote:0cdf5de569="rasmataz"]Sounds more like its coming from the transmission[/quote:0cdf5de569]
so i should just get that checked instead of changing the transmission fluid to see if that does anything? Also my dad who had this car said they replaced the computer with a used one hopefully it's not that.
thanks
Dec 19, 2007 at 1:27 PM
Try changing the fluid and filter make sure you use the correct type of fluid.
Dec 19, 2007 at 2:07 PM
