1993 Lincoln Continental Brake booster 93 lincoln continent
1993 LINCOLN CONTINENTAL
JOHNANTHONYHOME
  • 8 POSTS
Brakes problem
1993 Lincoln Continental 6 cyl Front Wheel Drive Automatic 150k miles
Could someone please post up the closest thing to the actual ford procedure for removing and replacing the brake booster, and master cylinder. Please?
Dec 29, 2008 at 5:52 PM
JOHNANTHONYHOME
  • 8 POSTS
How much money do I need to donate to get this answered?
Dec 29, 2008 at 9:01 PM
IMPALASS
  • 3,112 POSTS
Hello - There doesn't seem to be very good pic on this in the manuals I have looked at. They only provide general instructions........ So what I did was give you the pics they gave on disassembly so you can see the item....and then the instructions for removal for the master cylinder. They showed two types....I attached them both........ Also, they don't even supply removal of the booster..........however, once you have removed the master cylinder, remove the vacuum hose from the booster....from inside the vehicle under the dash you will get to the bolts/nuts that hold the booster on........
https://www.2carpros.com/forum/automotive_pictures/248015_1_134.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_2_86.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_3_60.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_4_37.jpg
Removal and Installation of Master Cylinder Notes On models equipped with ABS, depress brake pedal several times to exhaust all vacuum in the system. On all models, disconnect brake lines from master cylinder, then all necessary electrical connectors. On models equipped with ABS, disconnect hydraulic control unit supply hose at master cylinder. Secure hose in a position to prevent brake fluid loss. On all models, remove nuts retaining master cylinder to brake booster. Remove master cylinder. Reverse procedure to install. After installation is complete, fill master cylinder with manufacturer recommended brake fluid and perform brake bleeding procedure.
Dec 30, 2008 at 1:49 AM
JOHNANTHONYHOME
  • 8 POSTS
there is not enough room to pull it out, several brackets must be removed from the top of the transmission. the cruise control solenoid, several wiring harnesses, etc.
Dec 30, 2008 at 6:14 AM
IMPALASS
  • 3,112 POSTS
Hello –
Are you talking about the master cylinder or the booster?
Dec 30, 2008 at 8:04 AM
JOHNANTHONYHOME
  • 8 POSTS
I hired a pro! LOL. Was happy to give donation though. Thnks anyway.
Dec 30, 2008 at 10:04 AM
