1990 Lincoln Continental Lift Control, Compressor problem
1990 LINCOLN CONTINENTAL
97,500 MILES • 6 CYL • 2WD • AUTOMATIC
SMKEAST
Switch is in trunk, yuck, but I have to overfill the air, especially in back then turn switch off, and it will stay for a while, but when it falls, it falls. There is a small leak drivers side back wheel, I can hear it, but you can lift it above the leak, then it will fill up. I then have to let air out of the front because when it is overfilled, the brakes don't work very well.
Is the computer in the compressor, and where are instructions or diagrams of the air hoses, and how the compressor should be hooked up?
Thank you
Sue
Aug 24, 2009 at 7:58 PM
BLUECOLLAR
  • 86 POSTS
If the rear is going down, the rear air struts are leaking. No matter what else you do, there's no way to keep the rearend up very long.
You may want to think about doing a coil spring conversion. It'll save a ton of cash in the end:
Aug 24, 2009 at 8:43 PM
