summer months windows, locks, other features do not work and engine will stall when door is opened.
if a button is pressed on the control panel, the dome lights come on and go off. Now the charging system alert is coming on as well. I may have two problems caused by the short. The battery was replaced in august of 2008 and this started. Now the car will not even start. the battery was checked again, the positive cable was just replaced, the hot wire from the positive terminal was replaced, and the solenoid works if a screw driver touches it, but not when started with the ignition switch I get nothing from starter or anything else, but have lights.
May 5, 2009 at 3:02 PM
