1990 Lincoln continental 3.8 115,000
1990 LINCOLN CONTINENTAL
KHAAN
  • 10 POSTS
I was wondering if you could tell me what I am leaking coolant from. It is located on top of the engine near the air filter housing and it is left of the thermostat. I can see coolant coming out of a small pipe (about an inch or so in diameter), that comes out of the engine and has a plug that plugs in on top of it. I do not see a hose that fell of or was removed from it and I have taken the entire air filter housing out. Do you maybe know what this is and where it should lead to. THANKS, Kyle
May 22, 2006 at 11:56 PM
LOSONE
  • 1,616 POSTS
Replace the heater bypass hose and that should fix the problem.
May 23, 2006 at 2:41 PM
