1972 Lincoln Continental C6 Tranny
1972 LINCOLN CONTINENTAL
58,700 MILES • V8 • 2WD • AUTOMATIC
AMIFAN
Hi, my problem is that the C6 Transmission does not shift in any forward gear when it is cold. Reverse is no problem. If you wait about 2-5 min with engine running then you can drive without any problems for the rest of the day. Oil is changed and level is fine. Best regards Bastian
Sep 5, 2010 at 11:58 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Problem described is worn rubber seals in TRANS that allow fluid loss in cletch pack pistons until warm when things expand a bit. No solution other than overhaul.
Hope this helps
Thanks for donate
Try this go to parts house and get an additive for trans seals may work
Sep 6, 2010 at 12:20 PM
