Limp mode
2004 VOLKSWAGEN JETTA TDI
196,000 MILES
EF411
  • 11 POSTS
ABS light on, check engine light on, no brake light on.
Do I follow the three steps on checking when the ABS light is on? Please advise.
Jul 6, 2017 at 4:17 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
I posted how to retrieve the engine codes for the check engine light. I also posted the ABS code retrieval process.The first thing I need from you is the exact code numbers not code descriptions for the engine and ABS. That is the first thing I would do is if I had the car in front of me.
Jul 6, 2017 at 6:15 PM
EF411
  • 11 POSTS
18033 and 18057
Jul 11, 2017 at 6:53 PM
EF411
  • 11 POSTS
They both have p codes: P1649 and P1625.
Jul 11, 2017 at 7:04 PM
SATURNTECH9
  • 30,869 POSTS
Which model is this you mentioned the model?
Jul 12, 2017 at 6:47 AM
EF411
  • 11 POSTS
Passat wagon ???? TDI 2.0L. Does that help? 2004 B5
Jul 12, 2017 at 8:46 AM
SATURNTECH9
  • 30,869 POSTS
Iam sorry I forgot to ask you what your vin number was when i asked you for your model?Trying to see what I can find for this issue.
Jul 12, 2017 at 5:06 PM
EF411
  • 11 POSTS
Its wvwve63b44e274205
Jul 12, 2017 at 6:52 PM
SATURNTECH9
  • 30,869 POSTS
Your going to have to check the fuses if there good you have a bad and control module.I spoke with my shop foreman and we discussed it.Very common for the and modules to fail on those cars.Also it can put the car in limp mode and set the code for no communication with the transmission computer.Do you have traction control or 4 motion?I need to know so I can get you the correct fuses to check.
Jul 13, 2017 at 1:03 PM
EF411
  • 11 POSTS
I know that it's not 4-motion, it is FWD.
Jul 14, 2017 at 12:36 PM
SATURNTECH9
  • 30,869 POSTS
Do you have traction control?Are there little skid marks lighting up on your dash?
Jul 14, 2017 at 12:46 PM
EF411
  • 11 POSTS
Yes
Jul 14, 2017 at 2:04 PM
SATURNTECH9
  • 30,869 POSTS
I posted a diagram of the fuses to check.
Jul 15, 2017 at 8:22 PM
EF411
  • 11 POSTS
Thanks. I'll check.
Jul 16, 2017 at 6:51 AM
EF411
  • 11 POSTS
God bless you!!!
Please let us know what happens. SaturnTech9 is one of our best!
Jul 17, 2017 at 1:27 PM
EF411
  • 11 POSTS
I checked the fuses and the relays on the drivers side under the dash. They seem to be well seated and checked okay. I'm going to try to get an ABS pump module from the salvage yard. I don't want to experiment with a Bosh costing $750!!!
Jul 18, 2017 at 1:51 PM
Jul 18, 2017 at 3:28 PM
EF411
  • 11 POSTS
I have a pic from today.
Jul 18, 2017 at 5:32 PM
SATURNTECH9
  • 30,869 POSTS
There 160-233 on rock auto depending on which one you need.I also have a 5 percent discount code for rock auto.I wouldn't recommend getting a junk yard one.I have seen customers do that and they etheir get the wrong one or one that is no good.
Jul 18, 2017 at 5:36 PM
