OKay,
700 is a general code for transmission issue.
the 888 is your issue. it looks like it is an electrical issue such as wiring or a bad transmission control module.
When Monitored:
Continuously
Set Condition:
This DTC is set when less than 3 volts are present at the Transmission Control Relay output circuits at the Transmission Control Module (TCM) when the TCM is energizing the relay. Note: Due to the integration of the Power-train and Transmission Control Modules, the transmission part of the PCM has its own specific power and ground circuits.
888 possibilities
P0888
Descriptor
Relay Output Always Off
Probable Causes
Fused B+ Circuit Open
Intermittent Wiring and Connectors
Power-train Control Module (PCM)
Transmission Control Relay Control Circuit Open
Transmission Control Relay Control Circuit Short to Ground
Transmission Control Relay Ground Circuit Open
Transmission Control Relay Output Circuit Open
Transmission Control Relay Output Circuit Short to Ground
Transmission Control Relay Stuck Open
499 this is an evap code and has nothing to do with your issue
P0499
Descriptor
Nvld Canister Vent Valve Solenoid Circuit High
Probable Causes
Good Trip Counter Equal to Zero
Ground Circuit Open
Natural Vacuum Leak Detection (NVLD) Solenoid Control Circuit Open
Natural Vacuum Leak Detection (NVLD) Solenoid Control Circuit Shorted to Battery Voltage
Natural Vacuum Leak Detector (NVLD) Solenoid
Vehicle History and Service Bulletin Investigation
622 is a charging system issue
P0622
Descriptor
Generator Field Control Circuit
Generator Field Not Switching Properly
Probable Causes
Alternator
Generator Field Coil Open
Generator Field Coil Shorted
Generator Field Control Circuit Open
Generator Field Control Circuit Shorted to Battery Voltage
Generator Field Control Circuit Shorted to Ground
Generator Field Driver Circuit Open
Generator Field Driver Circuit Short to Ground
Generator Field Ground Circuit Open
Generator Field Performance
Generator Field Source Circuit Open
Dec 28, 2018 at 8:22 AM
