limp
2000 MERCURY COUGAR
100,000 MILES • 2.5L • V6 • FWD • MANUAL
STEVE DRAKE
  • 8 POSTS
I was pulling out of store like normal and kinda jamming on it then it through two codes and is like its in limp mode. I only get like half throttle response. seems to run fine at low rpms. I reset them but, they were p0500 and p1131. It's still running the same but, I haven't driven it enough for the codes to come back. I recently changed the fuel pump and speed sensor. The used motor was just put in when I bought it.
Sep 4, 2016 at 8:47 AM
HMAC300
  • 48,601 POSTS
0500 is speed sensor in trans which could be bad or it's a wiring issue/pcm problem. for 1131 see pic for problems associated with it also check fuel pressure with a gauge auto parts rent it.
Sep 4, 2016 at 10:51 AM
STEVE DRAKE
  • 8 POSTS
I already changed vss cause the speedo doesn't work and the old wires were twisted. Never through that code till now. I've changed fuel pump three times. Maybe its a faulty pcm and shorting things out? Only driven like 20 miles since used motor put it.
Sep 5, 2016 at 6:06 AM
HMAC300
  • 48,601 POSTS
the speedo not working may be a bad dash causing that . check the items that are in pic like partially clogged egr system etc. or vacuum leak. also the people that changed the motor may have done just that and not changed oil etc.
Sep 5, 2016 at 6:37 AM
STEVE DRAKE
  • 8 POSTS
I will check vacuum and egr. Its fresh oil, new alternator, third fuel pump and filter. I know it could use an air filter but, never saw that throw codes. Sat with bad gas awhile before me. Thanks.
Sep 5, 2016 at 6:48 AM
STEVE DRAKE
  • 8 POSTS
And new gas cap just to be sure. Lol
Sep 5, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
with three fuelpumps i'd think there is junk in tank and should be washed out. It shouldn't go through that many unless they are really a cheap brand.you should have 35-55 psi key on engine off. check fuel pressure then turn key off if it doesn't hold 5 psi within one minute then injectors or fuel pressure regulator is no good.
Sep 5, 2016 at 9:12 AM
STEVE DRAKE
  • 8 POSTS
I emptied and cleaned the tank before i put the last fuel pump in. the other two went cause of bad gas but, now this is different than before. before i couldnt even get it to run more than 5 minutes til the pump went. maybe clogged injectors? ran sea foam through before the last pump. not cheap pumps either. regulator didnt seem to be dirty.
Sep 5, 2016 at 10:29 AM
HMAC300
  • 48,601 POSTS
test it like I've said in last reply injectors can be cleaned professionally at a garage sometimes it works. not running more than 5 minutes I kind of doubt it's an injector. until you scan for codes and check fuel pressure you are just wasting money because you don't know where to go. also check intake for vacuum if 15" or below suspect a clogged exhaust.
Sep 5, 2016 at 11:59 AM
STEVE DRAKE
  • 8 POSTS
Thanks for the advice. I'll check some stuff tomorrow. I'm watching my son now. I'll update on the results.
Sep 5, 2016 at 1:15 PM
STEVE DRAKE
  • 8 POSTS
turns out it wasn't in limp. a plastic linkage between throttle cable and throttle body broke. some sort of limiter or something. im told that definitely would throw those codes because it controls fuel and air. I made a new one out of aluminum and it runs perfect. now i just need get my e-brake handle to stay engaged. Thanks for all the help. I'm sure i will be asking more advice.
Sep 9, 2016 at 3:37 PM
Glad we could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Sep 14, 2016 at 5:29 PM
STEVE DRAKE
  • 8 POSTS
Are there any common relays and such that would cause the trunk latch to not work? Ive changed the latch, key fobs and everything else works fine. next is to get an actuator if its not a hidden relay somewhere. I hear a slight click sometimes under the glove compartment when i hit the trunk button. maybe relays under there for it? I dont have a manual for it.
Dec 11, 2016 at 5:43 AM
HMAC300
  • 48,601 POSTS
check ground behind right kick panel then have it scanned for codes by a mechanic it may be the anti theft module acting up
Dec 11, 2016 at 4:27 PM
