Limited slip replacement
1999 CHEVROLET TAHOE
180,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
AMERICANCHADAZZ
  • 5 POSTS
I have the SUV listed above with a 3.73 rear end. The limited slip clutch went out and I cannot find a kit to fix it. So can I put in spider gears that is for a non limited slip or do I need to get a new carrier?
Oct 1, 2018 at 4:41 PM
Good morning.
I found both the carrier and just the clutches for replacement. I attached them both at the bottom.
I suggest replacing the carrier. If you have never done one of these before with the clutches, it can be a real pain.
Oct 2, 2018 at 3:40 AM
AMERICANCHADAZZ
  • 5 POSTS
I have seen the carrier assembly for the limited slip but it is more then I care to spend. The non limited slip is cheaper and I do not need posi. Would I need a new carrier to install non limited slip spider gears or can I use original?
Oct 2, 2018 at 7:42 PM
You can use the original with the clutches installed, yes.
Oct 4, 2018 at 5:50 AM
