lights will not go off even with key off
1995 FORD F-350
240,000 MILES • 7.3L • V8 • 2WD • AUTOMATIC
  • 7 POSTS
All the external lights stay on when you turn off key. The dinger still dings with out the key in ignition and the headlights and running lights stay on. Help please
Feb 14, 2016 at 3:11 PM
  • 7 POSTS
Sorry the problem is on a 95 f350
Feb 14, 2016 at 3:12 PM
HMAC300
  • 48,601 POSTS
this may be a bad headlight switch or it may be a drl module if you have daytime running lights check headlight switch first check the brown wire see if power is still going to it after switch has been turned off. it may also be your warning module but check the brown wire first as that can cause warning module to ding like it is. you'll have to get tit scanned to see if modules are problem.
Feb 14, 2016 at 3:54 PM
  • 7 POSTS
Completely unhooked switch and lights stayed on. Was told truck didn't have drl
Feb 14, 2016 at 4:21 PM
HMAC300
  • 48,601 POSTS
check body ground from battery and eng/battery grounds then otherwise unhook warning module and see if lights go out. if they do your module may be bad or something is powering it up like a melted harness etc.
Feb 14, 2016 at 4:24 PM
  • 7 POSTS
Changed switch and plug going into switch, still same problem. Not sure where warning module is located.
Mar 13, 2016 at 1:40 PM
HMAC300
  • 48,601 POSTS
try disconnecting anti theft module if lights go out the module is bad however your truck won't start
Mar 13, 2016 at 2:00 PM
  • 7 POSTS
There's a white plug and a black plug. Unplug the white plug and the dinner went off and the lights went off.
Mar 13, 2016 at 2:06 PM
  • 7 POSTS
Okay I'm hooked the white plug lights went out did start though. Do you think that the module is bad? Can I run it with a just unplug? Or do you recommend changing it?
Mar 13, 2016 at 2:23 PM
  • 7 POSTS
Un hooked white plug
HMAC300
  • 48,601 POSTS
try running it like that and if it gets to where it won't start try hooking the plug back up if it starts you are golden
Mar 13, 2016 at 3:39 PM
