Odometer light, dash lights and flasher are flashing
2000 FORD EXPEDITION
192,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
LAURIE HOFFER
  • 48 POSTS
Odometer light, dash lights and flasher all flash. Also, it sounds the the four ways are one, but there not once you go for about a minute it stops. did it awhile ago and my husband took to terminal off the battery put it back on seemed to be fine until yesterday. not sure if it is the extreme negative temperatures we are having. when it happened before it wasn't cold.
Thank you
Jan 31, 2019 at 12:28 PM
BMDOUBLE
  • 1,139 POSTS
Check the ground connections behind the left and right kick panels. Loosen the 8mm bolts and look to see if there is rust behind them......................................................................................................................................................
Jan 31, 2019 at 9:20 PM
