Parking lights do not work
1998 LINCOLN TOWN CAR
216,000 MILES • V8 • 2WD
KENNETH.DANIELS.ORG
No park lights. I replaced the light module still not working. Could it be relay switch? Is the horn and park light on the same relay switch?
Oct 19, 2017 at 3:51 PM
STEVE W.
  • 15,113 POSTS
Looking at the wiring diagram the most likely problem is a bad parking light switch section. Headlight control gets its power off the same fuse. The easy way to test it would be to run a jumper from the orange wire with white stripe to the white wire with a black stripe. That would bypass the park section of the switch. If the park lights come on, you have a bad switch. To test the light side of the system run a jumper from battery positive to the brown wire at any of the marker lights, they all feed from the same location.
Oct 19, 2017 at 6:07 PM
KENNETH.DANIELS.ORG
Thank you sir.
Oct 19, 2017 at 6:23 PM
Please let us know what happens so it will help others.
Oct 20, 2017 at 2:19 PM
