lights come on, car wont crank.
2000 HONDA PASSPORT
165,000 MILES • V6 • 4WD • AUTOMATIC
CHELCLYNNN
I have a 2000 Honda Passport. Whenever I crank it all my lights come on but the car won't crank/turn over. I've had the car for a little over a year & this makes the 3rd time this has happened. In the past, all I had to do was shove the car in park & it would start but this time that little trick isn't working and hasn't worked in about 2wks. Please help me!
Feb 6, 2014 at 6:08 AM
HMAC300
  • 48,601 POSTS
check the things I've pointed out in pic as well as battery condition including load test. you can switch a like relay to se if that is the problem. if still not starting if you can get an assistant try to start then hit he body of the starter with a hammer and if it starts you need a starter.
Feb 6, 2014 at 6:21 AM
CHELCLYNNN
Thank you for responding! & what pic?
Feb 6, 2014 at 6:25 AM
HMAC300
  • 48,601 POSTS
looks like I forg ot it sorry...here it is........
Feb 6, 2014 at 6:29 AM
