The code you indicate deals with swirl control valve position sensor voltage. Basically, the voltage is too high (above 4.8v). That shouldn't have anything to do with the hazard lights. The only thing I can think of is if somehow when replacing the coils/plugs, something was shorted, specifically the swirl sensor. That would indicate the high voltage, but not the lights.
I attached a pic below showing the location of the swirl control valve position sensor. It is in the rear of the engine. Check to see if anything has damaged the wiring to it and if something is shorted to it.
As far as the hazard lights, here are the diagnostics for testing. The remaining pics correlate with the directions.
2014 Lexus IS 250 RWD V6-2.5L (4GR-FSE)
Hazard Warning Switch - Inspection [04/2013 - ]
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Hazard Warning Switch Testing and Inspection Component Tests and General Diagnostics Hazard Warning Switch - Inspection [04/2013 - ]
HAZARD WARNING SWITCH - INSPECTION [04/2013 - ]
LIGHTING (EXT): HAZARD WARNING SWITCH: INSPECTION; 2014 - 2021 MY IS200T IS250 IS300 IS350 [04/2013 - ]
PROCEDURE
INSPECT AIR CONDITIONER CONTROL ASSEMBLY (HAZARD WARNING SIGNAL SWITCH)
Measure the resistance according to the value(s) in the table below.
Pic 2
If the result is not as specified, replace the air conditioner control assembly.
Illumination Inspection
Pic 3
Apply battery voltage to the air conditioner control assembly and check that the switch illuminates.
_______________________
Take care and God Bless,
Mar 3, 2021 at 8:00 PM
