Lights
1997 DODGE DAKOTA
214,000 MILES • 3.9L • V6 • RWD • MANUAL
DODGEOWNER21
Lights were working fine until me and friend went and pulled a few fuses out to look at them to see if they were okay the vehicle was off. We put them back and now when I pull the light switch when the vehicle is on the one fog light doesn't come on neither does the cluster lights. We think it could be the fact we didn't push the fuses in all the way, but the high beam and the fog light comes on when i pull the high beam switch what else could we check that would cause this problem? (low beams don't come at all.)
Jan 22, 2016 at 3:59 PM
WRENCHTECH
  • 20,761 POSTS
It's pretty obvious that something went wrong when you pulled the fuses. Double check them all and make sure they all went back into the correct slots.
Jan 22, 2016 at 4:26 PM
