lighting
1998 MERCURY SABLE
166,000 MILES • 6 CYL • FWD • AUTOMATIC
DKHUBBARD4
Warning lights and gauges work but instrument cluster nor the radio illuminate when headlight switch is turned on. Interior light only works by the manual switches on the light itself and tail lights do not work. What could be the issue?
Jan 16, 2016 at 6:41 AM
HMAC300
  • 48,601 POSTS
check the autotail lamp relay in box 1 for taillights. if not that then it may be either a multifunction or headlight switch. it may also be a bad cluster as they are digital and lights run through it.
Jan 16, 2016 at 7:38 AM
