The issue may be due to them not calling this a lighter any more. You may be using it for that but they called these power sockets which will accept one of those lighter inserts.
So it is fuse 18 in the fuse block on the inside of the vehicle, left side of the dash.
Here are a couple guides that will help with testing and replacing the fuses:
https://youtu.be/Hlna_kUt7As
Below you will find the info from the manual on this fuse. Please run through this material and let us know if you have other questions. Thanks
Jul 20, 2021 at 6:55 AM
