The vehicle overheated on me the other day because there was no water in the radiator, and started to make light white smoke from the exhaust whenever the car stopped. I also didn't drive for more than a minute when the car overheated. this only happens when the car is warmed up, I also got a misfire in cylinder 3, I changed the coil of cylinder 3 and changed all spark plugs, checked the cylinders ratio, they all run on the same frequency when accelerating, I added about 3 small bottles of fuel injectors, and I also checked the coolant reservoir and radiator, and they look good to me, no mixture of oil and water, and no leaks.
Apr 11, 2023 at 12:55 PM
