Okay here we go. Nine months ago put new multi-function switch and ignition switch in no problems just getting worn and lose. Everything worked fine until hooked up to boat then the nightmare started.
Here are the symptoms:
1. Ignition on running lights come on everything else okay.
2. Ignition on or off turn parking lights or headlights
on dash lights come on but turn indicators come in dash and should not.
3. Ignition on lights on turn indicators on dash light up but turn signals nor four way flashers work at all but brake lights do work. Also turn signals brighten a little with corresponding signal on.
4. Ignition on left and right rear signals work but both front signals flash as well as dash lights flash and both indicators. Then rear brakes applied one bright brake light comes on but not the one flashing.
Okay, here is what I have done:
Replaced flashing unit.
Replace both rear tail light assembly's
Disconnected rear plugin same results and it does have the towing package and trailer connection.
I replace the multi-function switch again. Thinking maybe it was defective.
It does have a remote starter for nineteen years and everything on it works fine.
Thanks in advance for any suggestions and I do not like wiring problems.
Nov 30, 2018 at 6:16 PM
