Light blue smoke from the exhaust
1997 PLYMOUTH NEON
155,730 MILES • 2.0L • 4 CYL • AUTOMATIC
ABRAHAM HAACK
  • 8 POSTS
Not sure when I press the gas pedal a little light blue smoke comes out but wasn’t doing that when my buddy test drove the car before I bought it. so I am not good at problems with cars.
Sep 10, 2019 at 2:41 PM
Blue smoke is oil burning in the combustion chamber and coming out the exhaust.
I would suggest checking the oil level each time you fill up with gas just to make sure you are not getting low. Then keep a case of oil in the trunk so that you can top it off as needed.
This is caused by the rings not keeping the oil out of the combustion chamber and will only get worse. If the engine was overfilled with oil then that will cause the same thing because the crankshaft will splash the oil up onto the cylinder walls and gets burned out that way. Once it is put back to the proper level this will stop.
Here is a guide that explains the condition in a little more detail:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Let me know if you have questions.
Sep 10, 2019 at 2:58 PM
Good evening,
Blue smoke indicates burning oil.
I would have a wet and dry compression test done. If there is a difference of more than 15% on each cylinder, the rings are worn and that is the reason for the smoke.
Sep 10, 2019 at 3:09 PM
ABRAHAM HAACK
  • 8 POSTS
Can you still drive it like that?
Sep 10, 2019 at 3:49 PM
Yes, you can but keep an eye on the oil level.
Sep 10, 2019 at 3:52 PM
ABRAHAM HAACK
  • 8 POSTS
Okay, thanks for your time.
Sep 10, 2019 at 4:27 PM
You are welcome.
Always glad to help.
Sep 10, 2019 at 4:53 PM
ABRAHAM HAACK
  • 8 POSTS
Would the light blue smoke go away if it’s been sitting probably not the issue though just wondering.
Sep 11, 2019 at 5:11 AM
No, not really.
There is oil in the cylinders and that's why it is burning blue.
Sep 11, 2019 at 5:17 AM
I agree. The issue is the bottom ring on one or multiple of the pistons is allowing oil into the combustion chamber. So when he says that it’s burning oil that’s how it’s getting in there. If the car has been sitting more than likely these rings are seized and allowing oil past them. There is a small chance that as the car is run they could release and start blocking the oil again but this is a very small chance.
Roy‘s advice of just checking the oil level regularly is your best course of action at this point and get as much life out of the engine as possible.
Sep 11, 2019 at 5:29 AM
ABRAHAM HAACK
  • 8 POSTS
Then that’s what I will do.
Sep 11, 2019 at 5:32 AM
Keep us updated.
Sep 11, 2019 at 5:34 AM
ABRAHAM HAACK
  • 8 POSTS
I will keep you updated and how much to fix probably not worth fixing.
Sep 11, 2019 at 5:53 AM
You would be talking about an engine overhaul.
That would be around $3,000.00 to $4,000.00.
Sep 11, 2019 at 5:55 AM
ABRAHAM HAACK
  • 8 POSTS
I am running it until it dies then I will keep filling the oil.
Sep 11, 2019 at 6:05 AM
Sounds like a plan.
Sep 11, 2019 at 6:08 AM
ABRAHAM HAACK
  • 8 POSTS
How many miles can you go if your burning oil but filling it?
Sep 11, 2019 at 6:19 AM
You can go a lot of miles. Just do not let it get low in oil.
Sep 11, 2019 at 6:23 AM
