Lift-gate issues
2014 TOYOTA HIGHLANDER
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLAKE LOUVIERE
Hello, I have been having issues with my lift-gate. The issues have actually been lasting a couple of years. The rear power lift-gate generally opens up all of the way with no issues, however when it closes, it generally stops about 2/3 of the way down. I'm not sure if a sensor is bad or getting tripped, if the motor is bad, or if one of the struts is bad. I tried doing some sort of a reset procedure that I read about online but it didn't seem to help. It doesn't do this 100% of the time, but it does it most of the time. Any help would be greatly appreciated. FYI i'm a good friend of Ryan's! Thanks!
Jul 27, 2019 at 1:42 PM
Welcome to 2CarPros.
When it stops mid way, do you get two beeps? If so, there is a technical service bulletin (TSB) that was published related to the symptoms. I will attach the TSB for your review.
Here is the TSB. The attached pictures all correlate with the directions.
BODY - POWER LIFTGATE STOPS DURING OPERATION
pic 1
T-SB-0027-15
May 20, 2015
Power Back Door Stops During Operation
Service Category
Vehicle Exterior
Section
Door/Hatch
Market
USA
pic 2
Applicability
Introduction
Some 2014 2015 model year Highlander vehicles may exhibit a condition in which the power back door starts to open or close normally, then intermittently stops and beeps twice. In most cases no current DTC is present, but DTC B2226 or B2227 (PBD Unit Pulse Sensor LH/RH Circuit) may be in history. Follow the Repair Procedure in this bulletin to address this condition.
Production Change Information
pic 3
This bulletin applies to vehicles produced BEFORE the Production Change Effective VINs shown.
pic 4
Warranty Information
pic 5
Parts Information
Repair Procedure
1.Set the power back door opening adjustment to position 5 (maximum opening position).
Refer to the Technical Information System (TIS), applicable model and model year Repair Manual:
^ 2014 Highlander / Highlander HV:
Vehicle Exterior - Door/Hatch - "Door/Hatch: Power Back Door System: Customize Parameters"
^ 2015 Highlander / Highlander HV:
2.Operate the power back door, and confirm the following conditions are met:
^ The power back door starts to open or close, then stops before fully opening or closing.
^ Two short beeps are heard when the door stops.
NOTE
The two short beeps heard when the condition occurs match the sound heard when jam protection is activated.
^ The back door can be opened and closed manually.
Are the conditions mentioned above met?
^ YES - Continue to step 3.
^ NO - This bulletin does NOT apply. Continue diagnosis using the applicable Repair Manual.
3.Remove and replace the LH and RH power back door actuators (Unit Assy Set, Power Back Door) with the NEW parts.
Refer to TIS, applicable model and model year Repair Manual:
Removal Procedure:
Vehicle Exterior - Door/Hatch - "Door/Hatch: Power Back Door Drive Unit: Removal"
Installation Procedure:
Vehicle Exterior - Door/Hatch - "Door/Hatch: Power Back Door Drive Unit: Installation"
4.Perform the power back door initialization procedure.
Vehicle Exterior - Door/Hatch - "Door/Hatch: Power Back Door System: Initialization"
5.Confirm normal operation of the power back door.
Vehicle Exterior - Door/Hatch - "Door/Hatch: Power Back Door System: Operation Check"
_________________________
Jul 27, 2019 at 6:47 PM
BLAKE LOUVIERE
Thanks for the quick reply. I guess the good news is that now I know what's going on. The bad news is it's going to cost an arm and a leg to fix. Appreciate the help!
Jul 27, 2019 at 7:33 PM
Welcome back:
I take it the TSB was accurate for the symptoms and conditions you are experiencing. I would contact Toyota and let them know this has been going on for a long time and no one was able to repair it. Maybe they will help. It never hurts to ask.
Take care and let me know if I can help.
Jul 27, 2019 at 9:04 PM
