When replacing the camshaft can I use the old lifters?
1993 FORD THUNDERBIRD
160,000 MILES • 3.8L • V6 • 2WD • MANUAL
AKIRK18
  • 7 POSTS
I replaced old camshaft and am going to install old roller lifters. Is this safe to do or do I need to buy new lifters?
Oct 3, 2020 at 10:53 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Due to each cam lobe and lifter having different wear and wear patterns it is always advisable to replace lifters when installing a new camshaft. I would not suggest re using old lifters. Hope this helps and thanks for using 2CarPros.
Oct 3, 2020 at 12:53 PM
AKIRK18
  • 7 POSTS
How about push rods ?
Oct 3, 2020 at 11:07 PM
AKIRK18
  • 7 POSTS
I have brand new rockers.
DANNY L
  • 5,648 POSTS
Hello again.
New rockers are a great idea as wear for the same reason being wear pattern. You can reuse push rods just be sure to measure them to be sure they are all the same length and not bent. As far as testing to see if they aren't bent just roll them on a flat piece of glass. Hope this helps and thanks again for using 2CarPros.
Danny-
Oct 4, 2020 at 12:04 AM
