The rear lift gate will not open when the engine is off and the key is out. Neither the key fob,the gate switch button or the overhead dash switch.
Dec 7, 2019 at 1:33 PM
CERTIFIED EXPERT
It sounds like the motor or module could be bad. To be sure lets run some simple tests, first let's check for power at the LGM and OBS DET fuses under the hood and inside the car. Here is a guide to help us and the fuse locations along with the lift-gate wiring diagrams so you can see how the system works:
Dec 8, 2019 at 5:46 PM
JCMYGATT
MEMBER
the life gate will open when the engine is running but not when the engine is shut down. where should i look to fix this problem?
Jan 24, 2020 at 3:24 PM
CERTIFIED EXPERT
Okay, this sounds like an operational error which the BCM handled which could be going bad. To be sure lets do a CAN scan which is the future of automotive repair. you can get a CAN scanner from Amazon for about $40.00. here is a video to show you how:
