I'm replacing the lock actuator on this SUV listed above and am on the 99 yard line. I have the actuator unbolded, the latching mechanism unbolted, the yellow clips on the side latching rods unclipped but there is another rod, the one that connects the latch handle on the outside of the lift gate to the latching mechanism inside the door. It is also attached with a "clip" but, for the life of me, I can not figure out how this clips works, that is, I can not determine how it 'unclips' , can not see a 'tab' or a hinge side on the clip, can not tell if it opens up, down, inboard or outboard. Can you provide advise, or a picture of this plastic 'quick disconnect' clip ? I don't want to break it. Again, its rod that connects the interior mechanism to the exterior flipper handle. With this problem overcome, I can remove the mechanism and replace the actuator (rod) then reassemble.
Jun 30, 2020 at 3:22 PM
