License plate light not working
2005 PONTIAC G6
155,000 MILES • V6 • 2WD • AUTOMATIC
PRINCESS77ASH
  • 6 POSTS
so I was going to change the bulb. I got the light out and changed bulb and went to put back in slot to screw it back on, and the light fixture fell down in the hole and I can't fit my hand down in it to find it. What do I do?
Apr 27, 2019 at 7:47 PM
CARADIODOC
  • 34,307 POSTS
Fashion a hooked tool out of a piece of mechanic's wire.. That's just soft steel wire on a roll. You can make a stiffer version of the same thing out of a piece of coat hanger wire. Pass the hook around in the hole until you snag the wires, then gently pull them up and out.
Apr 27, 2019 at 8:33 PM
