License plate lights not working?
2013 CHEVROLET VOLT
192,961 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MATTHEWMORGAN880
I don't have any license plate lights working, both are out and need to know if I have a fuse issue or what is the problem.
Dec 4, 2022 at 7:50 PM
The power to the license plate lamps is provided by the body control module (BCM).
Have you checked the bulbs themselves? If you look at the first two pics below, they are the directions for replacing the bulbs.
If you have checked the bulbs, we need to check if there is power to them and if they are getting a ground.
If you look at pic 3, it provides the wiring schematic for these lights. Note the power is from the body control module via a light green wire with a yellow tracer. With the lights on, check to see if there is power to that wire at the light socket. All you need is a test lamp or a multimeter.
If there is power, then we need to check for continuity to ground via the back wire at the connector.
Let me know what you find or if you have questions.
See pics below.
Dec 5, 2022 at 6:19 PM
