1992 Lexus SC 400 starter
1992 LEXUS SC 400
150,000 MILES • V8 • 2WD • AUTOMATIC
THOMASDITTERT
how do i remove the starter on a 1992 Lexus SC 400?
Dec 16, 2008 at 11:42 AM
JH0962
[quote="thomasdittert"]Engine Mechanical problem
1992 Lexus SC 400 V8 Two Wheel Drive Automatic 150000 miles
The starter is under the intake. (I recommend you read my post, user jh0962) Disconnect battery, drain coolant, remove TB cover,air intake ass.,throttle cable,TB(throttle body),wire covers,VSV,timing belt covers,hoses,wires, intake chamber,fuel lines,egr pipe,fuel rail, intake manifold, water bypass pipe, disassemble engine harness casing,remove water bridge and starter. (well worth the $500 in labor) Parts: intake gasket set, injector seal kit, water Bypass (bridge) gaskets, EGR gaskets, hoses etc
May 30, 2010 at 12:01 AM
