2004 Lexus RX 330 brake fluid leaking
2004 LEXUS RX 330
118,000 MILES • V8 • AWD • AUTOMATIC
I brought my rx 330 to the dealer because the brake light came on. They said the brake fluid level was low and that fluid was found inside the power brake booster. I was also told to fix the problem the brake master cylinder and power booster assembly would need to be replaced. Estimated cost of repair was over $1000. Does that seem right?
Oct 30, 2009 at 5:25 PM
DODOMA
3/26/12: I receive about a month ago a recall notice from Lexus informing me that there is a recall to replace the rubber cups in the master cylinder (mc). I took the car to the dealer and on removing the mc, they found fluid in the booster. The booster will be replaced under the recall.
Mar 27, 2012 at 1:13 AM
