2002 Lexus RX 300 front end/steering wheel wobble
2002 LEXUS RX 300
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEKERSEY
i recently noticed that the front end/steering wheel has a shake/wobble to it when i apply the brakes....I had the pads changed with ceramic pads and did not have the rotors turned.they looked fine.any ideas? The tires seem to have good tread on them.
Apr 20, 2008 at 10:26 AM
SUSMAN28888
  • 62 POSTS
Hey there-
If the steering wheel is shaking and wobbling when you apply the brakes then your rotors are warped. you cant look at rotors to see if there fine, you need to mic them. Replace the rotors, do not turn them, its more expesinve and the warping will come back in a few thousand miles, you will have to check the pads too because when pads wear to warped rotors it will wrap the pads, so for now, just replace the rotors see if that fixes it, it should, if not replace the pads. and never go off of, "they looked fine"
Sep 11, 2008 at 4:32 PM
