2001 Lexus RX 300 CHECK ENGINE LIGHT
2001 LEXUS RX 300
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
KELLY4578
CHECK ENGINE CAME ON ABOUT 45MILES AFTER I HAD PUT NEW BATTERY IN . I ALSO PUT FUEL CLEANER IN THE CAR. THE CODES ARE P1130 and p1135
Jan 12, 2009 at 12:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like your vehicle did not like the fuel cleaner you used. CODE P1130
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_125.jpg
CODE P1135
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_127.jpg
I suggest driving the vehicle through another fuel cycle with the recommended octane level. Then reset the engine code and see if it comes back. I believe the fuel cleaner just messed with some of the sensors and the computer is giving off a "false alarm". Hope this helps.. Thanks for using 2carpros.com!
Jan 12, 2009 at 12:33 AM
