2001 Lexus RX 300 anti skid
2001 LEXUS RX 300
ANTHONY MAZZIOTTI
  • 6 POSTS
Brakes problem
2001 Lexus RX 300 6 cyl All Wheel Drive Automatic
I just replaced the Left rear wheel bearing, now the anti skid light comes on and the car boog down then goes . once it goes it's fine till you stop or turn, then it boogs and chatters.
Aug 1, 2009 at 1:54 PM
ANTHONY MAZZIOTTI
  • 6 POSTS
[quote:79644bacc6="anthony mazziotti"]Brakes problem
I just replaced the Left rear wheel bearing, now the anti skid light comes on and the car boog down then goes . once it goes it's fine till you stop or turn, then it boogs and chatters.[/quote:79644bacc6]
Aug 1, 2009 at 2:30 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_438.jpg
Check for damaged ABS speed sensor pull codes good luck
Aug 1, 2009 at 10:56 PM
ANTHONY MAZZIOTTI
  • 6 POSTS
tried that , OK
Aug 2, 2009 at 10:08 AM
ANTHONY MAZZIOTTI
  • 6 POSTS
that was the first thing I checked , there was no damage to it.
Aug 2, 2009 at 10:14 AM
BMRFIXIT
  • 19,053 POSTS
Use an ohm meter and check it
disconnect it and ohm check for continuity
and need to have the ABS system check for codes
Aug 2, 2009 at 7:34 PM
