2001 Lexus RX 300
2001 LEXUS RX 300
PUDDO
2001 Lexus RX 300 6 cyl
How do you replace the power antenna
Jun 8, 2009 at 11:31 AM
WUTSIZFACE
Really was not too hard. You need to go in through the back trunk area on the right. Find the screws along the interior that hold the hard plastic interior molds in place. Remove. Remove the little cubby hole on side as well. Open up teh right side interior and teh antenna will be in sight. There are only a couple screws/nuts holding it in inside above wheel well and taking off teh nut on top (where antenna comes out. Slide assembly out through inside. Replace assembly. In and out inside of an hour.
Jun 26, 2009 at 2:05 PM
