2000 Lexus RX 300 Oxygen sensor
2000 LEXUS RX 300
CAMDEN
Engine Performance problem
2000 Lexus RX 300 114000 miles
When my check engine light came on, I was told that one oxygen sensor was not working. I was told then that I should replace BOTH sensors since the 2nd would go soon after the first. Is absolutely necessary and what will happen is I don't do anything at all?
Thanks you so much for your time.
Jan 15, 2009 at 12:09 PM
NYC.ECHO.LEXUS.TECH
  • 20 POSTS
DO YOU REMEMBER WHAT CODES YOUR WERE GIVEN?
USUALLY THE SENSORS BEGIN TO FAIL AFTER 90K OR SO . IM NOT SAYING THE REST OF YOR SENSORS ARE BAD BUT USUALLY A/F SENSORS WICH ARE THE FIRST IN BANK ONE AND BANK TWO OF THE ENGINE USUALLY
FAIL CAUS E THE HEATER INSIDE THE SENSOR WEARS OUT IF ITS AN AIR-FUEL SENSOR HAVE BOTH CHANGED
IF ITS AN OXYGEN SENSOR HAVE THAT ONE REPLACED
THATS JUST GENERALIZING THE CIRCUMSTANCE
MORE DETAILS NEEDED TO TRY TO SEE WHAT YOU GOT
Jan 17, 2009 at 6:28 PM
